I purchased the development board of IM828XCC.
I tried to test today, but IMC101 development board is not connected. I don't know why. I just unboxed and tried, but it doesn't work.
Viewed the data sheet.
I need to remove the onboard interface, what is the onboard interface?
Hi @JasonLEE ,
Please remove the chip highlighted and use iMOTION link to program the board.
Hi @JasonLEE,
For using the iMOTION Link to program Eval-M1-101TF please remove the connection to the on-board debugger. This is necessary to avoid interference between the two debug/PC interface ICs.
Please refer to the section 5.2 Connect with iMOTION Link to MADK boards in the AppNote Interfacing with iMOTION™ products .
Krupashankar
I already referred to this part.
But I don't really understand this part.
Can you explain?
You mean remove this chip?
Hi @JasonLEE ,
