When TLE7182EM chip is in use, the input IH1 is set to high level, then why does the GH1 output have 10V voltage? According to the specification, this pin is valid at low level, so the input IH1 is high level. When TLE7182EM is in use, the input IH1 is set to high level. Then why does the GH1 output have a voltage of 10V? According to the specification, this pin is valid at low level, so the input IH1 is high level, and the output GH1 should be 0V
This is a duplicate thread of the: TLE7182EM
Please, refer to the answer to the above thread.
Thank you
Best Regard
Raj Chaudhari
Thank you
Best Regard
Raj Chaudhari
