Motor Control ICs Forum Discussions
sohail
50 sign-ins 10 questions asked 10 replies posted
Hi@ Krupashankar
                                      I am Trying to Read IU current Value when I send Command
Note: Motor is Stop mode not running
0x01,0x05,0x01,0x7A,0x00,0x00,0xFE,0x80
data received
0x1,0x85,0x1,0x7A ,0xF9,0xFF,0x5,0x1
Motor Ampere iU = FFF9,in decimal = 65529
again Send
data received
0x1,0x85,0x1,0x7A,0x5,0x0,0xF9,0x0
Motor Ampere iU = 5,in decimal = 5
I don't understand Why I get FFF9 value?
when I run motor  got Correct Rpm by reading Register   0x7D; // Motor speed Register 125=7D
but IU current give 40,60,70 Reading & also FFC9 or different value FF
PL guide what I am doing Wrong & From where FF values came.
Krupashankar
Moderator 250 replies posted 100 solutions authored 5 likes given
Hi @sohail,
Register Iu is a signed 16-bit value representing the current in the U phase so you are reading both positive and negative current.
For more details please refer to section 3.2.7.1 Iu in iMOTION SRM.
Please let us know if further details is needed.
Krupashankar
Viswa
Moderator 10 solutions authored First like received 100 sign-ins
Hi Sohail,
Thanks for reaching to us, please provide the iMOTION controller and the evaluation board used for this project?
Best Regards
sohail
            I am Using I motion2GO Board.
Krupashankar
Hi @sohail,
Krupashankar
