User20393
Distributor
10 replies posted 10 questions asked 25 sign-ins
Hi
My IMC101 is working well with UART Control Interface.
However after using script of
UART_DriverInit(1 /*channel*/, 0 /*rxInvert*/, 0 /*txInvert*/, 2400 /*baudrate*/, 8 /*dataBits*/, 0/*parity*/, 1 /*stopBits*/);
UART_FifoInit(8 /*rxFifoSize*/, 8 /*txFifoSize*/);
The UART Control Interface is no longer working.
For instance. Motor Coltrol: Command 0x03 is not working and no reply
PS
I'm using this script to  set the global variable  thru UART.
RupakC
100 solutions authored 250 sign-ins 25 likes received
Hi @User20393
It seems that you have configured UART1 as a control interface.
But inside the script we could see that you have again initialized UART1 in script.
This is not allowed. You can use UART1 either as a control interface or use in script as a peripheral.
I hope the above information helps you to resolve your issue.
Thanks and Regards
RupakC
RupakC
Hi @User20393
Thanks and Regards
RupakC
