I have MADK board EVAL-M1-301F. In the user guide I found that:
Access to MCU via SWD debug channel (Segger® J-Link light)
Looking through schematics I cant find needed signals in the isolated part of the board. I can only see that connector X102 has traces with the on board debugger XMC4200 pins P2.4, P2.5, P2.8.
Could you clarify the X102 connector pins purpose and how to program the MCU of the IMC301A-F064 in this board? (Keil uVision5 CMSIS pack installed, code compiled, do not know how to properly flash and debug).
Hi
MCU on IMC301A-F064 can be programmed through the micro-USB connector available on the board.
To program the iMOTION controller(T-Core) MCE Designer can be used.
To program (A-Core) in Keil we can select SWD programmer.
Viswanadham Y
Hi
Viswanadham Y
