JasonLEE
100 replies posted 250 sign-ins First like received
Hello
I changed winding for motor stator.
Because It was to problem of overtemperature.
So It changed the spec on Ld , Lq , Back EMF (ke).
Originally this motor is working well but after winding changed it have problem is flux.
After changed , It have another problem of flux estimator.
Motor is working well but 300rpm situation is have error code on flux out of control
It does not rpm ramp up
I don't know this cause.
Can you help me this problem?
I attached this video and parameters.
Please check it.
Viswa
10 likes received 50 solutions authored 100 replies posted
Hi @JasonLEE
Improper configuration of the following lead to Flux out of control Fault:
  • Incorrect number of pole pairs
  • Improper configuration of Flux estimator time constant( usually 4 to 5 times of L/R)
  • Improper configuration of PLL KP and PLL ki
Please configure all the above parameters and let us know the results.
Best Regards
Viswa
Hi @JasonLEE
Best Regards
