zak_by11
10 sign-ins 5 sign-ins First reply posted
I am trying to ensure correct SPI communication with TLE94103 component, and the problem that i faced is that i always get NPOR  bit set to zero even if i send a clear for global status register it is always set to zero so i always have global error set.
Looking forward for your help, thank you.
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi @zak_by11,
In the Global status register the NPOR bit has to be set(1) to clear the NPOR status.
Additionally, could you please confirm the SPI settings as per mentioned in section 5 SPI protocol of the TLE941xy of Application Note  . The most important point to note is that data is sent in LSB first (byte by byte) refer to Figure 6 in the Application note.
Please use Multi Half Bridge Library as a reference.
Thank you
Best Regards
Raj Chaudhari
Raj_C
Hi @zak_by11,
Thank you
Best Regards
Raj Chaudhari
