Motor Parameters. Speed Ramp Rate Open Loop Speed Ramp Rate Parking Time Low Speed Threshold Low Speed Current Limit whether these parameters need to be filled in the motor configuration file?
Hi @DevendraKumar ,
The details are required for the motor configuration to be complete in case of closed loop control of PMSM/BLDC motors.
For controlling Induction motor the essential parameters are PWM frequency, Number of motor poles and motor max RPM.This document explains about induction motor control Induction motor control by iMOTION™ .
Hi @DevendraKumar ,
Can I run Induction motor in Reverse direction using Kit?
Yes it is possible, based on the direction input.
Section 2.2.1 provides more details on Reference generator block.
Please go through Section 2.1.8 in iMOTION™ Motion Control Engine
for further details on using control input.
Hello Vishwa,
Can you please help to set Motor protection features in the Tool .
Please suggest how I can Enable Motor Protection features in the tool and see the SW Faults
Thanks & Regards
Devendra
Hi @DevendraKumar,
Motor fault protection can be enabled from MCE Wizard Ques 68 to Ques 74 or It can be enabled from MCE designer by writing corresponding values to each register mentioned below.
For more details please refer to section 3.2.8 Protection Register Group of iMOTION™ Motion Control Engine Software Reference Manual
Krupashankar
Hi Krupa Shankar,
Is there any motor protection feature related to Phase reverse.
Thanks & Regards
Devendra Kumar
There is no protection for phase reversal.
It has to be detected based on the application.
Best Regards
I have tested this but Motor Runs in Anticlock wise, I think If someone reverse phase then Motor Should be stopped. Is there any this type of Protection in this VFD kit ?
Based on the direction of rotation we should observe if either current or speed is higher or lower in one direction when compared to other and implement the solution as desired.
Best Regards
Hi Vishwa,
How to set Phase loss detection in the MCE designer tool and how I can see this in log.
Please help me.
Thanks & Regards
Devendra
Please check Section 2.1.16.6 Phase Loss Protection in software reference manual.
Best Regards
