I have an EVAL-M1-101T-T038 and an EVAL-M1-IM323. I have not used any Infineon products before. I have watched several videos including How to get started with iMOTION™ 2.0 by Infineon4Engineers. I have also read the user's manual.
I downloaded the latest MCEWizard and MCEDesigner (both v 2.3.0.1). I setup the motor parameters in MCEWizard and saved the file. When I attempt to open an irc file in MCEDesigner I get Error: Could not open file (x86)\Infineon\iMotion2.0\MCEDesigner_v2.3.0.1\IMC101T_v1.03.03.irc. I read in the forum that if this occurs you should uninstall both software packages and install an earlier version. I did this and installed version 2.2. I got the same error. I uninstalled v2.2 and reinstalled v2.3. To make sure that I didn't have a corrupted IMC101t**.irc file, I downloaded the irc file for the IMC101T-V1.02_20_iMotion2Go and got the same error. I have a USB cable connected to the EVAL boards and they are powered. I am running Windows 7 sp1.
Hi @dnthomason ,
Windows PC with remote access can be used. Shadow is a powerful Windows PC you can access remotely. It is compatible with USB peripherals. So ideally it should work.
As remote PCs also have limitations, it is recommended to use Infineon tools on your host Windows machine. Please update your computer to the latest Windows version. Windows 10 will work.
Please upgrade your windows and then install MCEDesigner or use a new Windows machine.
Ninad
Hi @dnthomason
We have not noticed such an issue to date, is it possible to use either Windows 10 or 11?
Best Regards
Dennis Thomason
Hi @dnthomason ,
Ninad
