MCE Designer becomes unresponsive and no longer able to turn off the Motor every time I tired to run PFC first and then run Motor.
But there is no problem if I turn on only one(either pfc or Motor) and run.
The tools that I use for this application are: EVAL-M3-302F for controller and EVAL-M3-CM615PN for power board. I have the latest version of MCE designer installed which is v2.3.1 and the MCE wizard that I have is v2.3.1. The firmware package that I use for board is IMC302A-F064 MCE Software Package v1.3.3
- IMC302A
- MCE designer
Hi @sudip_k,
Can you please share the Trace settings in MCE Designer?
Please try reducing the sample rate.
Please follow below steps to reduce sample rate for the trace:
- Right Click PFC_VacRaw & PFC_IpfcRAW
- Select >> Define Trace
- Reduce the sample rate and try
Please try above setting and let us know if this helps to solve the problem.
Krupashankar
Hi @sudip_k,
Please try installing other versions of MCE Wizard from Tool Brief MCEWizard v2.3 and please let us know if this solves the issue.
can you please let us know the following:
- Windows Version
- If any active trace is enabled in MCE Designer and its setting
Krupashankar
Hi, thank you for the reply. I have tried installing the older version too but the problem still exists. Should I try installing all the older versions one by one and check?
I have windows 10 and there is no active trace enabled.
Hi @sudip_k,
Apologies for the delayed response.
Can you please try using a different PC and see if the problem still persists?
Krupashankar
Hi @sudip_k,
Krupashankar
Now I am able to work with MCE designer after reducing the MCE cpu load by slightly decreasing the Motor PWM frequency. And also by the changing sample rate.
