Someone Pl Guide how to Get Variables Data in MCE Designer.
As per doc 2.6.5 Variable types and scope
Script engine supports maximum of 30 global variables, these variables can be accessed from both the task. Each tasks has maximum of 24 dedicate local variables. These local variables can be only accessed with inrespective task. All the variables are 32 bit signed variables. Only global variables can be accessed from MCE Designer or User UART interface.
In MCE Designer I can see Register but no real time value change. Can I see variable values?
MOTIX™ MCU
Hi @sohail,
Yes, only Global variables can be accessed using MCE Designer.
Yes, Please follow the below steps:
- Right Click on >> Monitor Definitions >> Create new monitor Group >> Give a desired name
- Right click on newly created monitor group >> Define Trace >> add the global variables from the list
- Expand the monitor group and setup trace
These steps will help in watching the real time change of the global variable.
Please let us know if any further clarification is needed
Krupashankar
Hi @sohail,
Krupashankar
Hi @Krupashankar ,
Thanks for Help, I am able to Run my First Script & Can See the Global Variable Value in MCE-Designer Changing.
Thank you🤗
