Infineon TLE9563-3QX Not working in Closed loop with PMSM motor
BichoyEssam
First question asked Welcome!
We have the TLE9563-3QX on a PCB that we made (Not Dev Kit) but we are 100% of the connection.
When we run the PMSM motor in OpenLoop : The Chip takes the 6 PWMs from the Microcontroller and open the Gates correctly.
But when we do the same procedure for Closed Loop:  The Chip takes the 6 PWMs from the Microcontroller but have no output on the Gates.
When we checked the Failure Flags, we had no flag for this issue.
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi @BichoyEssam,
Could you please let us know what is the Hardware setup and the firmware being used?
Thank you
Best Regards
Raj Chaudhari
