I try to use Imotion Link with Eval-M1-101TF with MCE Designer but it not connect. I am using Eval-M1-101TF stand alone no external power is connected.
Imotion Led Status
3.3v out Red Led is on
Debug Green Led is on
Com Led is off
If I use usb connection MCE Designer works fine. what will be the Problem.
Hi @sohail,
For using the iMOTION Link to program Eval-M1-101TF please remove the connection to the on-board debugger. This is necessary to avoid interference between the two debug/PC interface ICs.
Please refer to the section 5.2 Connect with iMOTION Link to MADK boards in the AppNote Interfacing with iMOTION™ products .
Krupashankar
Hi @sohail,
Krupashankar
