IMC300 with CMSIS RTOS on Keil
yarzar
First reply posted First question asked 5 sign-ins
Does IMC300 support CMSIS RTOS2 on Keil? After I include CMSIS RTOS library into the project, I can build successfully with compiler v6. When I try to debug it, it never came into the main(). I unticked the "run to main" in keil and debug it, it was stuck in the hard fault handler in the startup file.
It was successfully build and debug without CMSIS RTOS2 library. Kindly look for your advice. Thanks!
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @yarzar,
Thanks! for posting in the Infineon Community.
We will try to reproduce the issue at our end and get back to you.
Krupashankar
shirazmacuff
I had problems running my code on the ARM core on IMC301A.
The problem was resolved by enabling JCOM in MCE wizard.
You may want to try that.
Shiraz
Hi Shiraz,
I've tried that. But it's still the same.  Thank you very much.
