I tried running the motor by sending target speed command via uart. It ran successfully.
However, the return value of the MotorSpeed from the IMC102T controller via uart is a very large number of 2bytes.
How do I convert this MotorSpeed read value to actual rpm of the motor?
Hi @sudip_k,
Motor Speed in RPM can be calculated using this formula:
Speed in RPM ={ (Motor Speed( 2 bytes) / 16383) * Motor MAX RPM( Configured in MCE Wizard) }
Please let us know if any further details are required.
Krupashankar
Hi @sudip_k,
Krupashankar
