sahayacharles
First question asked First reply posted Welcome!
I can't able to communicate with IMC101T-F048 IC.
This is the second IMC101T-F048 IC I have changed. While first-time programming(Firmware & parameters ) it connecting and programming are fine. After the first programming, I am not able to communicate with IMC101T-F048, and after 2 seconds from power on time the IMC101T-F048 indication LED gets down(OFF condition).
While I open the MCE designer application at LED ON condition (first two seconds at power ON time), it communicates successfully. After the two seconds LED OFF time, I cannot able to communicate with IMC101T-F048 IC.
Viswa
10 likes received 50 solutions authored 100 replies posted
Hi @sahayacharles ,
In the thread links provided herewith various methods to establish communication with the iMOTION device are outlined in-case of a failure. Please try to follow them and let us know if your issue is resolved.
https://community.infineon.com/t5/Motor-Control-ICs/IMC101T-F048-not-responding-to-UART-commands-fro...
https://community.infineon.com/t5/Motor-Control-ICs/imc102-i-motion-link-communication-problem/td-p/...
Viswa
Hi @sahayacharles ,
