IMC101T-038T UART Fault
wang1
Level 4
Level 4
50 questions asked 10 likes given First solution authored
Thanks for respones. You can see all part of circuit diagram below except HV Dc voltage side.
First of all the circuit scheme is for prototype so for this reason , didnt care too much for clean schematic.
At the diagram there is a rectangular that says " didnt soldered" , means that all of those components not soldered and remained open.
If any missunderstood please let me know
LinGuohui
500 replies posted 50 likes received 250 solutions authored
For user mode UART link break fault,  you can use clear fault command to clear the fault flag, and then maintain communication with MCE. MCE can return to normal.
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @wang1,
Can you please attach the schematic/Circuit diagram as mentioned above?
Krupashankar
LinGuohui
