I want to adjust the starting mode. I want to inject current into the Id shaft of the motor to align the rotor with the stator position before starting into the open loop starting. How to achieve this? The reason is that I want to increase the starting torque of the motor, so that when the motor is blocked, a certain torque will be generated to shake off the blocked object.
Hi @wang1,
The parking method can be used to align the motor in a known position.
Parking can be enabled by setting ques 12- Parking Time to a non-zero value.
Parking is not suitable for application that requires high starting torque at zero speed.
Please let us know if any further information is required.
Krupashankar
Hi @wang1,
Krupashankar
