mar9341
First like given First reply posted First question asked
In the previous Motor control device from Infineon (for example IRMCF341 or IRMCF343), there was a diagnostics mode called "current reg diagnostics" to help tuning the current control loop. A square wave signal created as a reference in order to see the step response from the current control loop. Is there similar functionality for IMC10x series ? Or could be it be created by the use of a script? Thank you.
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @mar9341,
Please follow the below steps in iMOTION Solution Designer:
1) Open -> Dashboard -> APP_MOTOR0 and update below:
     AngleSelect = Openloop Mode
     CtrlModeSelect = Current Control
     MinSpd = 0
     TargetSpeed = 0
      IdRef_Ext = 25%
2)Attach current probe to U-phase cable of the
motor.
3) Change current regulator values (KxIregD, KxIreg, KpIregD, KpIreg) in ① .
Select Angle Select = Openloop Mode, and
Current Control = Current Control in ②
Press "Update" button.
4)Press "Start Motor" button. Then rotor starts and vibrates. Press "Stop Motor" when vibration stops.
5)Change IdRef_Ext = 10%. Repeat 3.
6)Change IdRef_Ext = 50%. Capture step response of U-phase current by oscilloscope.
Please let us know if any further details are required.
Krupashankar
Krupashankar
Hi @mar9341,
     MinSpd = 0
     TargetSpeed = 0
      IdRef_Ext = 25%
motor.
Krupashankar
