The imotion link probe is not available.
The datasheet has little information and does not work when set as shown in the datasheet.
Can you help me remotely?
I have additional questions.
The LED on the IMC chip flashes at high speed.
Why is that? Please reply. Thank you.
Hi JasonLEE,
I found a problem in your picture, see below. You should use iMotion Link serial port instead of the SWD port. More information about iMotion Link see :iMOTION_Link-UserManual
There are usually two LEDs on the IMC board. One is to indicate the system status. If MCE is in fault status, the LED will flash. The other LED indicates PGOUT. If PWM is output, it will flash.
Hi JasonLEE,
