Hello ,
- IMC302A
- Script coding
Hi @Mohsin82214,
For MCU UART communication please refer to UART Example in IMC300A examples
For JCOM communication Please refer to JCOM Example in IMC300A examples for more details please refer to section 2.4 JCOM Inter-Chip Communication in iMOTION – MCE – Software Reference Manual v1.3
Please let us know if further details are needed.
Krupashankar
Hi @Mohsin82214,
To program and use the GPIO and ADC pins, please follow the process outlined in the document Please refer to Page 104, section 2.6.11.4 User GPIOs : iMOTION™ Motion Control Engine Software Reference Manual
The script that follows provides an example to use the same.
Krupashankar
Hello ,
I want to use P202,P206,P208 .
Can you please tell me how could i access these pins .
I want to use indoor uart can please tell me how to configure this uart .How to send and receive data to this UART.
Mohsin khan
Hi @Mohsin82214,
We assume you are using IMC302A-F064 based on tags and pin number. Please share the exact controller if we are wrong.
In the case of IMC302A-F064, this is a dual-core controller which has MCU and MCE. For more details please refer to the iMOTION™ IMC300A Data Sheet
For pins P2.02 P2.06 and P2.08 these pins have to be configured in MCU as ADC input channels. You can configure these pins using Register BRSSEL or using write_ADC_ChannelSelection0_RSSEL(CHSEL0_This_channel_is_part_of_the_scan_sequence); In Keil project.
For configuring ADC please refer to the ADC code example in the zipped folder: IMC300A examples
If you are planning to using pins of MCE ( T-core) you can follow the method shared in previous post.
Can you please explain about Indoor UART? UART can be configured as USER UART or MCE UART from the MCE Wizard tool. For more details please refer to Getting Started with iMOTION™ 2.0
Krupashankar
I am using REF-Aircon-C302-IM564 . In which controller is IMC302A-F064 .
By indoor UART i mean to say that i want to use P200,P201 named 1 14 RX_insider and 1 17 TX_insider .
I am attaching picture here .
I want to use JCOM communication protocol on this module . How to use it as i want to get and give data from 1 14 RX_insider and 1 17 TX_insider .
Hi @Mohsin82214,
Krupashankar
