We have a motor controller designed using IMC102T-f64 and is communicated via a host microcontroller using uart. The application requires the motor to stop running as soon as the host controller is turned off.
1. How do I make the motor stop from running if UART link is broken?
2. How can I make the motor stop if the master is not sending any command for an interval say 10ms?
I can't seem to find these settings on MCEwizard.
Hi @sudip_k c
Please go through the following thread, this provides solution for the same
https://community.infineon.com/t5/Motor-Control-ICs/uart-link-break/td-p/365024
Hi @sudip_k c
