Viswa
10 likes received 50 solutions authored 100 replies posted
Hi
In this case the parameter and script .ldf fie can be provided to the customer, they can use any of our production programmers to update the code to the solution designer.
Best Regards
Viswa
Hi
Best Regards
Mahimc2020
25 sign-ins 10 questions asked 10 replies posted
Thanks again. please introduce a software that could program .ldf file (extracted from iSD) directly to MCU (IMC102T-F064), without using iSD.
Viswa
Hi
The following link details of a mechanism to update the F/W for iMOTION controller from a secondary microcontroller. This is a mechanism available to program the device.
https://www.infineon.com/dgdl/Infineon-AN2018-33_iMOTION_2.0_Device_Programming-ApplicationNotes-v01...
Best Regards
Hi
Can i use  Flash programmer programmers to update the code to the solution designer ?
following link details :
https://www.elprotronic.com/pages/imotion
Viswa
Hi
Yes Elptronic is one of our preferred vendor and develops gang programmers/production programmers for iMOTION controllers. These can be used to program the iMOTION controllers with .ldf files.
Best Regards
