Motor Control ICs Forum Discussions
KK1
Hi Sir/Madam,
I would like to confirm is the Pin of 39 & 40 of IMM101T-046M, is that necessary to mount on PCB Board ?
I had check the PCB Layout of EVAL-IMM101T ( iMOTION™ MADK Starter Kit for IMM101T Smart IPMs),
-->  there is no solder pad on it.
But information in Datasheet,  Note is mentioned :
--> " Pins 39 and 40 are not required to be connected electrically on the PCB but are recommended to be soldered for mechanical stability. "
Does it means the pad need or need not to solder on board ?
Pls advise.  Thanks.
Viswa
25 solutions authored 50 replies posted 250 sign-ins
Hi @KK1
We are absolutely sorry for the delay,
as mentioned in the datasheet, pins are to be soldered to the PCB.
Viswa
Hi @KK1
