cw2611
25 sign-ins 25 replies posted 10 questions asked
Hey!
I want to run a 36V BLDC motor with peak current at 11A. Do you have any evaluation board that contains both the microcontroller as well as the half bridge? I want to implement FOC.
psb
250 sign-ins 25 solutions authored 100 replies posted
Hello @cw2611 ,
   Can you please let us know the following information :
1. DC Bus Voltage Range
2. Maximum continuous output current (at lowest inout voltage, max torque, etc)
3. Starting current
4. Application for which you need the design.
We have the following boards.
EVAL-M1-05F804R
EVAL-M1-05F310R
REF-VACUUM_C101_2ED
Kindly let us know of the details, and let us know if these boards work out for you as well.
Sai
NXTY_hayashi
Level 6
Level 6
Distributor - NEXTY (Japan)
50 solutions authored 25 solutions authored 50 replies posted
I recommend you to change the category iMOTION to XMC or PSoC. Because this category iMOTION is not microcontroller.
Kazunari Hayashi
psb
Hello @cw2611 ,
3. Starting current
EVAL-M1-05F804R
EVAL-M1-05F310R
REF-VACUUM_C101_2ED
Sai
