EVAL -M1-301F user examples not working
Swap26
First like given 5 sign-ins First reply posted
I am using IMC301-F064 based EVAL-M1-301F control board. I am trying to run the user peripheral sample examples but when I try to build the project it is showing following error:
' linking...
.\Objects\IMC302A_CCUPWM.axf: Error: L6200E: Symbol SysTick_Handler multiply defined (by ..\..\..\..\..\packs\ARM\CMSIS\5.9.0\CMSIS\RTOS2\RTX\Library\ARM\RTX_CM0.lib(irq_armv6m.o) and .\objects\main.o).'
I tried the solution mentioned on the ARM community https://developer.arm.com/documentation/ka002799/latest/ , but I cannot figure out how to remove the library file from the project.
Looking forward for the solution.
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @Swap26,
We were successfully able to build the project.
Can you please try uninstalling/removing the existing library files to avoid the error.
Krupashankar
Krupashankar
Hi @Swap26,
Krupashankar
Swap26
Hello @Krupashankar ,
I removed the library files. It built successfully. Thanks for the same.
But now when I try to load it in the target device it shows:
No Cortex-M SW  Device Found
Please help me with this.
Thanks again
Krupashankar
Hi @Swap26,
Can you please confirm if the iMOTION device is powered?
If not please provide an external supply of 3.3V
Krupashankar
Swap26
Got it. There was an issue with the power supply. Thanks for the quick help.
