Converting leg shunt to In-line current sensing for 3 phases on IMC301
shirazmacuff
Figure 8 in the IMC301 software manual shows leg shunts (low side of the bridge) for phases A,B and C.
Does the control algorithm support in-line current sensors on the motor  wire ( output of the bridge) for Phases A,B and C?
Shiraz
Krupashankar
500 replies posted 50 likes received 25 likes received
Hi @shirazmacuff,
iMotion MCE presently doesn't support in-line current sensing. Could you please modify your sensing to be either Single shunt or leg shunt measurement Could you please share your schematics?
Krupashankar
Krupashankar
Hi @shirazmacuff,
iMotion MCE supports Single Shunt and Leg Shunt current measurement. Could you please let us know why you want to use in-line current measurement and share your application need?
Krupashankar
Krupashankar,
We are would like to design-in the IMC301 on a controller card upgrade. The remaining sections  (power stage and sensing ) has to remain untouched for the most part.
Thanks for your help
Shiraz
Krupashankar
Hi @shirazmacuff,
Krupashankar
