BTS7960 burn
CloudRain
First question asked Welcome!
why is my bts7960 ic always broken even though the ic is not hot and doesn't take up much power. For wiring and power supply I can say it's good because I've tried it with other h bride drivers and it runs smoothly. As far as I know the ic is always broken when the 5v logic voltage input is cut off. the last damage when the motor is rotating, the 5v logic input voltage is cut off and can no longer be used.
Raj_C
500 replies posted 50 likes received 250 replies posted
Hi @CloudRain,
As per the Infineon Search for Discontinued Products, the BTN7960B product is discontinued we recommend using the active preferred part. BTN8982TA can be used as a replacement part.
Thank you
Best Regard
Raj Chaudhari
Raj_C
Hi @CloudRain,
Thank you
Best Regard
Raj Chaudhari
