Mac_Komatsubara
Distributor - Macnica (Japan)
First solution authored 25 sign-ins 10 questions asked
In p.32, Figure 20 of the BTN7030-1EPA data sheet, it is stated that DEN = EN = 0 must be kept for tstandby or longer as a transition condition to sleep mode.
How many seconds is this tstandby?
Komatsubara
RupakC
100 solutions authored 250 sign-ins 25 likes received
Hii @Mac_Komatsubara
The parameter tstandby is not defined for BTN7030-1EPA. It is considered that the device enters standby mode as soon as the conditions (EN = 0 and DEN = 1) are met .
RupakC
Viswa
10 likes received 50 solutions authored 100 replies posted
Hi @Mac_Komatsubara
We are working on your query, we will get back to you at the earliest.
RupakC
RupakC
Mac_Komatsubara
Hello Rupak
Thank you for your reply and answer.
In the datasheet, tstandby is described as a condition for transitioning from a certain mode to sleep mode. Is it correct to understand that it transits to Sleep Mode at the moment when EN = DEN = 0 is satisfied?
If the transition to Sleep Mode occurs at the moment when EN = DEN = 0 is satisfied, this condition (DEN = EN = 0
For t ≥ tstandby) should be deleted.
Komatsubara
RupakC
Hello @Mac_Komatsubara
Thank you for bringing this confusion to our attention. We will work towards correcting it in future revisions of the document.
RupakC
