6EDL7141 operating voltage(max)
NXTY_hayashi
Level 6
Level 6
Distributor - NEXTY (Japan)
50 solutions authored 25 solutions authored 50 replies posted
as the datasheet, the operating supply voltage (recommended operating condition) of 6EDL7141 is 60 V(max).
Supply voltage of Absolute maximum ratings is 70V(max).
Does it work with the voltage set to 65V?
Kazunari Hayashi
SuhasBobade
100 sign-ins 50 replies posted 25 solutions authored
As you mention, the recommended operating supply voltage of 6EDL7141 is 60 V(max) and this is the Infineon's recommendation for guaranteed performance.
This IC can take the voltage up to 70V. You can operate the IC at 65V as well but it will be borderline case and guaranteed performance can not be expected.
 And user should not cross 70V at any cost. This may damage the IC as well.
Hope this will clarify your doubt.
Kindly feel free to post your query.
Thanking you!
SuhasBobade
Thanking you!
