Frank_vec
Level 4
Level 4
Distributor - Zenitron(GC)
250 sign-ins 50 replies posted First like received
1、The modus Version: 3.2.0 2、'
2、I create a New application ,the procedure as below
the chip change to “CY8C4025LOI-T412” ,the clolk change from 48MHZ to 24 MHZ which was operated as the notes show //-->compile ok
The CY8C4025LOI-T412 project has 4 Buttons(P2.0 、 P2.3、 P2.4、 P2.5) and a I2C(P3.2 P3.3) that is different from the defaut prorammer .yet the progammer is changed //---compile error
#error The CAPSENSE(TM)Configurator requires anewer version of the CAPSENSE(TM)Middleware. Update the CAPSENSE(TM)Mddleware in your project.
#error #CY CAPSENSE BUTTON SELF CAP CLICKmain.c:176:26:error:TIMEOUT MAX VALUE'undeclared(first use in this function)
Project-Doesn-t-Reflect-Middleware-Version-Selected-Using-BSP-Assistant 这个我不明白写的啥,按照这个操作也解决不了 .the URL could not solve my problem
My number  :17317187679
Arpit_S
50 likes received 250 replies posted 100 solutions authored
Hi @Frank_vec ,
This is not correct. TO solve this, please follow below mentioned process:
1. Go to Edit Environment variable
2. Go to System variables
3. Add the variable CyRemoteManifestOverride and value = https://modustoolbox.infineon.com/manifests/mtb-super-manifest/v2.X/mtb-super-manifest-fv2.xml
4. After this, restart the ModusToolbox and check if you see MIDDLEWARE 5.0.0 or not
Kind Regards
Arpit Srivastav
ADSW
250 sign-ins 50 solutions authored 25 likes received
 Hello @Frank_vec ,
Have you update the MW-library through Library manager after change the device via BSP Assistant ?
Thanks & regards
Andri
Frank_vec
Level 4
Level 4
No
How could I update the   MW-library  ?
ADSW
Hello @Frank_vec
You can update the MW-library through LIbrary manager.
You can find it on the shortcut ( Tools area on the bottom - left side ) or by click Project > Modustoolbox > Library Manager.
Then, Update
Thanks & regards
Andri
Frank_vec
Level 4
Level 4
The  Sheild change to Ground
I have updated it ,the error still existed
Frank_vec
Level 4
Level 4
you can see the attachment which contian the project
ADSW
Hello @Frank_vec ,
I've checked on your project ( Library Manager ) the version of capsense MW is 4.0.0.
Could you please elaborate how this project works ?
Since i found the widget name is different with your code
but in your code still use BUTTON_SELF_CAP widget.
Thanks & regards
Andri
Frank_vec
Level 4
Level 4
Manager
  You can see the attachment ,not relative to the error
Arpit_S
Hi @Frank_vec ,
Please update the Middleware and it should solve the problem. Latest MIDDLEWARE is 5.0.0 as shown below, can you please update and see if this solves the issue?
Thanks!
Kind Regards
Arpit Srivastav
Frank_vec
Level 4
Level 4
Manager
 No  5.0 version
and the  have updated   "Latest 4.X release " Not OK
Arpit_S
Hi @Frank_vec ,
Kind Regards
Arpit Srivastav
Frank_vec
Level 4
Level 4
The  CyRemoteManifestOverride  is “https://mtbgit.infineon.cn/raw/Infineon/mtb-super-manifest/main/mtb-super-manifest-fv2-mirror.xml”  and will to be changed  to  " https://modustoolbox.infineon.com/manifests/mtb-super-manifest/v2.X/mtb-super-manifest-fv2.xml ";
This
phenomenon,and  error exsited ...
Arpit_S
@Frank_vec , Yes. Can you please do that and check if this solves the problem?
Frank_vec
Level 4
Level 4
I use the "Test_MSCLP_Self_Capacitance_Button_Tuning" project , and notes "
/* Check the used Middleware version */
ignore the "#error",and compile OK
Arpit_S
Hi @Frank_vec ,
Looking at the screenshots attached, I can see that there are no build errors. Thanks for sharing it.
Kind Regards
Arpit Srivastav
