Apr 25, 2022
06:46 PM
Apr 25, 2022
06:46 PM
Hi,when i building , the Console tab display success .but, in main.c ,the IDE cannot find where some .h file is referenced and list it as a unresolved inclusion .
Labels
ModusToolbox General
10:40 PM
Apr 25, 2022
10:40 PM
Hi @yoya_4785701 ,
This is an intelliSense issue. Can you please try the following:
1. Right click on the project >> Index >> Rebuild
2. Build the project
If the above did not resolve the issue can you also please try the below steps
- From the Project Explorer window, right-click on mtb_shared and select Delete. Do NOT select the check box Delete project contents on disk (if you do, you will have to regenerate it again).
- Select File > Import > C/C++ > Existing Code as Makefile Project and click Next >.
- Browse to the mtb_shared directory and click Select Folder.
- The Project Name will be filled in automatically.
- Select ARM Cross GCC for the toolchain and click Finish.
- To get IntelliSense to work again for an application you must re-build it first.
Warm Regards
Alen
10:40 PM
Apr 25, 2022
10:40 PM
Hi @yoya_4785701 ,
Warm Regards
Alen
