ModusToolbox™ General Forum Discussions
yoya_4785701
Level 4
25 replies posted First like given First like received
Level 4
  When I debug the program,How can I see the contents of a register。For example, tcpwm register。thanks!
Zhengbao_Zhang
Moderator First comment on KBA 10 questions asked 5 questions asked
Hello:
     Do you mean you want to see a specific register value of a chip when you are doing debug?
yoya_4785701
Level 4
Level 4
yes, i want  to see a specific register value 。
Zhengbao_Zhang
  from my experience, you need to add code to read out the value if you know the Register address.
Then you can add the address to the watch window, you can see the value change when you are doing debugging.
yoya_4785701
Level 4
Level 4
 the register address is 0x40380000, How can I add this address to the  watch window?
Zhengbao_Zhang
I think if the address is from a device, you need to add code to read it out to a variable with a period.
Then you can check the value of the variable.
