Hi
I am a bit concerned to the amount of bugs modus toolbox / IDE has. I am working with version 2.3 and pdl 3.15.
starting a new project from the new application window right from the initial stage the code is compiling with zero error . This sounds great but if you you look at warnings you will see the is a red cross in the CMSIS on the cm4 header file where it actual cant find reference to SHP and IP in the __STATIC_INLINE uint32_t __NVIC_GetPriority(IRQn_Type IRQn) code segment
in main.C it has "cy_retarget_io.h" as a include , yet the IDE also cannot find where this is referenced this and list it as a unresolved inclusion .
Library paths is as it gets setup from the new application platform creation , i believe this is causing a lot of issues in code compilation
how do we resolve these default code errors?
regards
ModusToolbox General
Hi @cc2380,
Can you please share a snapshot of the errors that you are referring to? From what I understand, I believe these are the IntelliSense errors where the IDE is not able to find the library, etc. These errors should not affect your project and you can ignore these errors.
Rakshith M B
Hi @cc2380,
Rakshith M B
HI Rak,
Thanks for responding. You seem to be right in terms of the compile and code . But if you want to see how something is declared and if it links up is problematic . Right clicking on the retarget_io.h and selecting to go to declaration is impossible .
Attached is the screen shots
regards
Hi @cc2380,
I do agree that it is an inconvenience when you are trying to navigate to see the declarations etc. There is an internal ticket regarding this and the team is working on how we can fix this issue.
Rakshith M B
