- Email to a Friend
hello, I install the new version 2.4.
Installed in : D:\Infineon\Tools\ModusToolbox.
set the environment variable:
when i create application, the console display as follows:
when the application is established, the console display as follows:
when i build project, build error as follows:
What's wrong with the setting?
thanks!
ModusToolbox General
- build eror
- Email to a Friend
Hi @yoya_4785701 ,
You have made a mistake while setting the environment variable path , i.e. please use forward slashes instead of backward slashes as below:
CY_TOOLS_PATH : D:/Infineon/Tools/ModusToolbox/tools_2.4
For more information refer the KBA231392.
Hope this helps
- Email to a Friend
Hi @yoya_4785701 ,
Hope this helps
- Email to a Friend
Hi @yoya_4785701 ,
Glad your query is resolved.
Thank you for using our products and please feel free to post any queries or issues you may face relating to our products in the community.
Thanks & Regards
Alen
