Getting error "MBEDTLS_HAVE_INT32/MBEDTLS_HAVE_INT64 and MBEDTLS_HAVE_ASM cannot be defined simultaneously" on build .Included WPA3 external supplicant library
ModusToolbox General
Hi @Anonymous :
Could you inform me which sample code project you're working on?
I will check this error and reply to you.
Colin
Its a AWS OTA with all the AWS libraries removed only using freeRtoS,light weight IP sockets, and all the middle ware libraries
Hi @Anonymous :
These definitions are defined in the library "mbedtls".
Could you check whether it is enable in Library Manager or not?
Colin
Hi, Included that library. Getting Error-
../mtb_shared/mbedtls/mbedtls-2.25.0/include/mbedtls/check_config.h:853:2: error: #error "MBEDTLS_HAVE_INT32/MBEDTLS_HAVE_INT64 and MBEDTLS_HAVE_ASM cannot be defined simultaneously"
853 | #error "MBEDTLS_HAVE_INT32/MBEDTLS_HAVE_INT64 and MBEDTLS_HAVE_ASM cannot be defined simultaneously"
Hi @Anonymous :
This error means your code define MBEDTLS_HAVE_INT32/MBEDTLS_HAVE_INT64 and MBEDTLS_HAVE_ASM simultaneously.
I build the original CE of AWS_IoT_OTA_Using_MQTT, and don't find this error.
I think maybe it's happened after you removed some library.
Could you add the library back one by one to find out which one cause this error?
Colin
