I am exploring using the CYW43907 in a product that would require WiFi Direct operation. I am currently using the CYW943907 devkit with ModusToolbox, since the WICED Studio SDK indicates "Not recommended for new designs."
I understand that WiFi direct/p2p mode was supported on WICED, but I cannot find the corresponding API in the ModusToolbox for WiFi API reference (I've been looking at the APIs listed in https://github.com/Infineon/modustoolbox-software).
Can anyone tell me if either a) what are the appropriate APIs to use or b) WiFi direct mode is no longer supported?
Thank you
Andor
ispn:36623:1:0
l1:3966:1:0
l2:6066:1:0
WiFi Direct (P2P) is supported on the CYW943907 in ModusToolbox, but the API has been updated from the WICED SDK. The APIs you should use are in the "wiced_wifidirect.h" header file, and the function names start with "wifidirect_".
Here is an example of how to initialize WiFi Direct:
arduino
Copy code
wiced_wifidirect_config_t config;
memset(&config, 0, sizeof(config));
config.group_owner_intent = 0;
strcpy(config.group_owner_intent_name, "MyDevice");
wifidirect_init(&config);
After initializing WiFi Direct, you can start a scan for other WiFi Direct devices using the "wifidirect_scan" function:
scss
Copy code
wiced_wifidirect_device_list_t device_list;
wifidirect_scan(&device_list);
You can then connect to a device using the "wifidirect_connect" function:
scss
Copy code
wiced_wifidirect_device_t device;
strcpy(device.device_address, "00:11:22:33:44:55");
wifidirect_connect(&device);
Note that the WiFi Direct API in ModusToolbox may differ from the WICED SDK, so you may need to refer to the ModusToolbox documentation or sample code for further guidance.
I have a similar problem. Can I use WICED on a CY8CPROTO-062S2-43439 or where to find this wifidirect_XXX apis in ModusToolbox? I have installed every example for this board but I haven't found it.
Thanks for your quick response, any chance you can point me to the repo that contains the wiced_wifidirect API you mention, or the ModusToolbox documentation or sample code locations you are referring to?
I have tried a variety of searches (google, github codesearch), but I cannot locate the wiced_wifidirect.h or any of the quoted functions. I am on the other hand able to find other APIs used by my project using the same searches, so I think my search method is valid.
