Hey I am new in using cypress. I am looking for a approach to my run cypress scripts automatically where my application code is deployed on Gitlab and I want that my scripts run every time after a code merge and before deployment. I would really appreciate some help.
ModusToolbox General
Consider making a Docker container in your repo, then add a runner to Gitlab to trigger a build each time a push is made. See more:
https://docs.gitlab.com/ee/ci/docker/using_docker_build.html
Could you please let me know the micro-controller or device you are using ? Which IDE are you using ? ModusToolBox ? Please let me know us more about your use case to help you better.
Vasanth
