gisc_1091076
10 replies posted 10 sign-ins 5 replies posted
I must update the my project create with modus 2.1 on modus 2.2. I have follows this guide :
MIGRATING APPLICATIONS FROM MODUSTOOLBOX V2.0/2.1 TO V2.2 - KBA231080
When i copy the files from old project (modus 2.1) on new project (modus 2.2), i obtain this error (i attached the log) :
source/task/ble_task.c:50:10: fatal error: app_bt_cfg.h: No such file or directory
In the modus 2.1 i haven't this error the build terminate correctly
1 - Why the new project return this error ?
2 - How can i import the wifi libraries in this project ?
This problem it's urgent.
Thanks you.
MuraliR_36
250 sign-ins 250 replies posted 100 solutions authored
gisc_1091076
In MTB2.2 complaint apps, app_bt_cfg.h is supposed to renamed as app_platform_cfg.c
If you get stuck in such issues in the future, please have a look at one of the standard MTB 2.2 examples and do a comparison of what is different in your application and you will be able to resolve things much quicker.
MuraliR_36
As this is a new issue away from the original question, please create a new thread so that visibility will be more and other users too who may face a similar issue in the future will have a reference.
MuraliR_36
gisc_1091076
sorry, i didn’t think about this solution because I thought it was a problem of porting of the project between modus 2.1 and modus 2.2.
