I'm using cy8ckit-149 and finding issue regarding Systick timer when I import LIN middleware in Freertos Code in ModusToolBox.
Since Systick Timer is used by RTOS for task switching as well as in LIN Middleware for BUS Inactivity, there is a conflict for both. The one which is initialised first will be working fine and the other one is not working.
So, how to resolve this issue .
ModusToolbox General
Hi @rajini ,
Can you check if both the middleware's are initializing the systick timer?
Can you also try to change the CLK SRC for freertos and check if that works?
Hi @Alakananda_BG ,
The Initialization of Systick is happening only in Freertos and in LIN I'm just adding a callback. Hence only RTOS is working as expected but not LIN.
Regarding CLK SRC i shouold run with SystemCoreClock. There is no possibility to change the clk src .
Is there any other possibility to make it work without changing the clock source?
Hi @rajini ,
Can you comment out the LINS_TimerDisableInt API and check if you are facing the same issue.
Hi @Alakananda_BG ,
I'm using LIN Middleware version V1.10.0 which is there in Modus Tool box. There is no such API in LIN stack.
I guess that API is in PSoc creator.
Could you please confirm that the API's that you are referring is in pSoc creater or Modustoolbox IDE.
Rajini
Hi @rajini ,
The API referred was for PSOC creator.
We enquired with the internal team and there are few questions for which we need answers
1)There can be a possibility that Customer has occupied all callback slots in SysTick Timer.
2)We need to know how many times the customer implementation of FreeRTOS calls the SysTick Timer.
Hi @Alakananda_BG ,
Sure I'll check and come back to you.
