YoIs_1298666
250 sign-ins 100 replies posted 100 sign-ins
I checked the box of "Use this as the default and do not ask again".
The next time I launch Modus Toolbox, I'll be taken to the last open workspace.
How can I restore the "Select a directory as workspace"?
Yocchi
Ekta
First like given 250 solutions authored 100 likes received
Hi @YoIs_1298666
The Use this as default workspace and do not ask again option will make the workspace you are opening as the default workspace. So the next time you open modustoolbox, a dialogue box wont prompt to ask you the path of the workspace you want to open, instead it will open the default workspace.
From your explanation it seems that this is working as expected. Kindly correct me if my understanding is not correct regarding the issue.
If you want to revert back this setting, you can do it in the following way:
In Modustoolbox go to Windows> Preferences > General > Startup and Shutdown > Workspaces and check the Prompt for workspace on startup box.
Thanks and Regards
Ekta
Ekta
Hi @YoIs_1298666
Thanks and Regards
Ekta
Hello Ekta-san,
Thank you for your reply.
That's good to know.
Yocchi
