I have two identical PSoC6 boards connected to my computer. How do I select a specific board to program by its KitProg3 serial number? I found that adding
make program _MTB_RECIPE__OPENOCD_CUSTOM_COMMAND='psoc6 allow_efuse_program off; adapter serial <serial>'
works but I am asking myself if this is the official way because
1. the name of the variable looks a bit like meant to be used internally only (leading underscore)
2. it repeats the default setting ('psoc6 allow_efuse_program off') as it overwrites the default value in the Makefiles
3. it requires the user to specify the serial number in openocd command syntax
What is the recommended way of specifying the serial number?
Looks like this is the only command
which is used to select a specific board to program by its KitProg3 serial number. You can verify the serial number of the devices by using the fw-loader tool using the command:
./fw-loader --device-list
Thanks and Regards,
Leo
Thanks and Regards,
Leo
Hi @user_4289666 ,
Thread was locked due to inactivity for long time, you can continue the discussion on the topic by opening a new thread with reference to the locked one. The continuous discussion in an inactive thread may mostly be unattended by community users.
Thanks and Regards,
Leo
