Request of environment check of ModusToolbox
MotooTanaka
Level 9
Level 9
Distributor - Marubun (Japan)
Dear all,
We have spent days of time to make one of my colleague's ModusToolbox work.
After all, the reason was that bash was disabled by our company's security regulation.
And so far, the two major barriers of ModusToolbox are bash and proxy.
I just wondered if ModusToolbox can check these at its startup time.
For example call bash for some trivial shell script and check the result
and access git hub only to check if it is accessible.
And if test fails inform the user that "You need XXX to use ModusToolbox"
23-Apr-2020
Motoo I like ksh better though, Tanaka
