riccardo-monty
50 sign-ins 10 replies posted First like received
Be aware on create a new application, when use workspace path the same of an imported application, on create confirmation, Project Creator start to create nested applications recursively and never stop!
AlenAn14
500 replies posted 100 solutions authored 250 replies posted
Hi @riccardo-monty ,
Very interesting and thank you for pointing this out to us.
I was able to replicate the issue and have raised a ticket to the internal team to fix the same in the next release of Modus Toolbox .
Thank you for using our products and do let us know of any such issues you face in our products in the future as well.
Alen
AlenAn14
HI @riccardo-monty ,
Can you please let us know the ModusToolbox version you are using?
I tried importing an existing application to the same workspace in which this application was present in ModusToolbox v 2.4.
In this case, since the application being imported already exist in the workspace, it creates a new application of the name " <imported application name>_1 ". If the '_1' is removed, it will give error saying that the same application name already exist in the workspace.
So it works fine without the recursion you have mentioned.
Alen
riccardo-monty
ModusToolbox v2.4
I admit it was my error on define path for create new application. It can be reproduced as following:
  1. Open Eclipse and define a workspace named "recursionIssue". Create a new Application, with BSP psoc63-proto and "empty_project", than close Eclipse.
  2. Open Eclipse again, use as workspace ".\recursionIssue\empty_project\", and import previous created application.
So happen for error if it is used as workspace an existing application, an you try to import that application
AlenAn14
Alen
