Be aware on create a new application, when use workspace path the same of an imported application, on create confirmation, Project Creator start to create nested applications recursively and never stop!
ModusToolbox General
- issue
Hi @riccardo-monty ,
Very interesting and thank you for pointing this out to us.
I was able to replicate the issue and have raised a ticket to the internal team to fix the same in the next release of Modus Toolbox .
Thank you for using our products and do let us know of any such issues you face in our products in the future as well.
Alen
HI @riccardo-monty ,
Can you please let us know the ModusToolbox version you are using?
I tried importing an existing application to the same workspace in which this application was present in ModusToolbox v 2.4.
In this case, since the application being imported already exist in the workspace, it creates a new application of the name " <imported application name>_1 ". If the '_1' is removed, it will give error saying that the same application name already exist in the workspace.
So it works fine without the recursion you have mentioned.
Alen
ModusToolbox v2.4
I admit it was my error on define path for create new application. It can be reproduced as following:
- Open Eclipse and define a workspace named "recursionIssue". Create a new Application, with BSP psoc63-proto and "empty_project", than close Eclipse.
- Open Eclipse again, use as workspace ".\recursionIssue\empty_project\", and import previous created application.
So happen for error if it is used as workspace an existing application, an you try to import that application
Alen
