We are making capacitive button (touchpad) on a custom HW. We are using a PSOC4 4100SP 128kB.
I have developped the firmware using ModusToolbox. Now I need to add a bootloader to the project. A UART based communication will be used (even if higher level proprietary protocol will have to be developped).
I have read several Cypress documentation on bootloaders and bootloadables but for PSOC4 all seems related to PSOC creator. The only information I found on ModusToolbox is related to PSOC6 DFU.
Could you please help.
Nicolas
ModusToolbox General
- psoc4 bootloader
You can refer to the below reference guide which has instructions for PSoC4 DFU.
https://infineon.github.io/dfu/dfu_sdk_api_reference_manual/html/index.html
You can also refer to the PSoC 4 DFU Middleware library.
https://github.com/Infineon/dfu/releases/tag/release-v4.10.0
Hello Alakananda,
Thank you very much
Nicolas
