ModusToolbox™ General Forum Discussions
MichaelF_56
AN225588 shows how to integrate ModusToolbox software into IAR Embedded Workbench (EW) or Keil µVision projects. You will learn how to configure your system to match your design, generate configuration code, and use that code in your project. When done, you will understand the resources available to you, and how to use them.
https://www.cypress.com/documentation/application-notes/an225588-using-modustoolbox-software-third-p...
