Modustoolbox 2.2.0 - USED Hardware summary - CY8CPROTO-062-4343W - PWM_Square_Wave Demo HAL
MaximePaille
I started using modustoolbox, I decided to start  with the pwm demo, because I want to control 30 pwm independently. From what I understood from the HAL interface, this interface makes it easier to use hardware modules.
I would like to know if it is possible to have a summary of the use of hardware modules by the hal library and the rest.
Maxime
Rakshith
250 likes received 1000 replies posted 750 replies posted
Hello Maxime,
According to my understanding, you are requesting a way to view a summary of all the resources that you have used, similar to the Resource Meter in PSoC Creator. Is my understanding correct?
At the moment, we do not think we have a way to view all the resources that are used by HAL drivers. Although I agree that a resource meter would make it easier to track the resource usage, as HAL is written only in firmware and does not have a dependency on Device Configurator, I am not sure how to achieve this. I will create an enhancement request so that the internal team can evaluate the same.
Thank you very much for your suggestion 🙂
Thanks and Regards,
Rakshith M B
Rakshith
Hello Maxime,
Thanks and Regards,
Rakshith M B
MaximePaille
Hello Rakshith,
Yes, that was exactly what I meant.
Thank you for your answer.
Maxime Paillé
