- Email to a Friend
I am trying to create a new application using the "Porcupine wake word demo". The demo will not create with the following error:
ERROR: Commit/tag/branch "v2.1.1" does not exist.
: Check that the commit/tag/branch in the .mtb/.lib file is valid.
: If working offline, check that your offline content is up-to-date
ERROR: --ABORTING--
: Script : C:/Users/mypath/ModusToolbox/tools_2.4/make/getlibs.bash
: Bash path : /usr/bin/bash
: Bash version: 4.4.12(3)-release
: Exit code : 1
: Call stack : trap_exit error perform_git process_mtb extract_data find_mtbs main
make: *** [C:/Users/mypath/ModusToolbox/tools_2.4/make/getlibs.mk:121: getlibs] Error 1
Project "Picovoice_Porcupine_Wake_Word_Demo_1" failed to create.
"make getlibs" failed.
Failed to create and export "Picovoice_Porcupine_Wake_Word_Demo_1" application.
Any ideas on how to fix this?
ModusToolbox General
- Email to a Friend
Hi @PatrickK_71 :
Thank you for your information, and we are checking this issue now.
Any result I will reply to you.
Best Regard,
Colin
- Email to a Friend
Hi @PatrickK_71 :
For this issue, it seems caused after "picovoice-lib-psoc6" version update, and it may fix in the further update.
Currently, I suggest you to Import Application again after failing to create the project.
The project is located in the default folder.
Then, modify the link in deps->picovoice-lib-psoc6.mtb(change 2.1.2 to 2.1.1).
After that, you can run "make getlibs" command in the terminal to import the libs.
Best Regard,
Colin
