MaMi_1205306
Level 7
Level 7
500 replies posted 50 solutions authored 25 likes received
Dear Sirs and Madams,
I asked the following questions in the past:
https://community.infineon.com/t5/ModusToolbox-General/Modus-Tool-Box-BSP-of-quot-KIT-XMC-2GO-XMC110...
I am trying to change it according to the procedure below, but I cannot successfully generate a custom BSP.
https://community.infineon.com/t5/Knowledge-Base-Articles/ModusToolbox-2-2-and-later-Make-a-Custom-B...
First, I found that the part number used in the command below was incorrect.
$ make bsp TARGET_GEN=MyBSP DEVICE_GEN=XMC1100_Q024x0064
The command will pass correctly if you change the part number.
$ make bsp TARGET_GEN=MyBSP DEVICE_GEN=XMC1100-Q024x0064
However, when I change the makefile to "TARGET = MyBSP", save it, and execute the "make config" command, the following error occurs.
Therefore, we cannot use the KITXMC2GO evaluation board with ModusToolbox.
Do we have no choice but to wait for the XMC1100 BSP to be released?
Is it possible to successfully generate a custom BSP for the XMC1100?
My development environment is as follows.
ModusToolbox 2.4
modus-shell 1.3.0
Empty XMC App of XMC-GENERIC BSP
For reference, either method (a) modus-shell 1.3.0 applicaion  or (b) Terminal of ModusToolbox will result in an error.
Vasanth
Hi Masashi-san,
The support for XMC1000 is not officially released yet. You may be able to use these features once BSP support for the same family kits area released.
Vasanth
Vasanth
Hi Masashi-san,
Could you please make sure that you don't have the device configurator(design.modus) open while you do this process ? Can you confirm whether the issue still persists after that ?
Vasanth
MaMi_1205306
Level 7
Level 7
Vasanth-san,
Even if you open ModusToolbox 2.4  and close device configurator 3.10, the error cannot be avoided.
If you enter the make config command in modus-shell without opening ModusToolbox, you will get the same error.
< modus-shell >
< Device Configurator error>
Is this an issue only for my development environment?
MaMi_1205306
Level 7
Level 7
The description of KBA231373 and the description of Modus Toolbox User Guide are different.
I tried a custom BSP along with "Modus Toolbox User Guide" instead of KBA231373
ModusToolbox User Guide URL
https://www.infineon.com/dgdl/Infineon-ModusToolbox_2.4_User_Guide-UserManual-v01_00-EN.pdf?fileId=8...
Follow the steps in "5.3 Creating your own BSP" on page 52 in order.
Of course, for the following commands described in step 2,
$ make bsp TARGET_GEN = MyBSP DEVICE_GEN = CY8C624ABZI-S2D44
The input has been changed as shown below.
$ make bsp TARGET_GEN = MyBSP DEVICE_GEN = XMC1100-Q024x0064
I was able to execute the command without any errors, but the device changes are not reflected when I open the Device Configurator 3.10.
MaMi_1205306_1-1643336913684.pngMaMi_1205306_2-1643336978614.pngMaMi_1205306_3-1643337014909.png
The device is still XMC1400 and has not been changed to XMC1100.
As a confirmation, is Vasanth-san able to change the device correctly?
Vasanth
Hi Masashi-san,
Vasanth
MaMi_1205306
Level 7
Level 7
Vasanth-san,
Thank you for your confirmation.
I was able to understand that the reason why I couldn't create a BCP for XMC1100 in Modus Toolbox was not a mistake due to my procedure.
I am waiting for the release of BCP for XMC2GO.
Is there a way to see in a list which devices are supported by Modus Toolbox?
